October 27th, 2016
What can you find in this newsletter: the release of Color Control GX v1.72 and a new version of VEConfigure, updated documents and the short stock list of 'old' Phoenix Inverters. The METS 2016 is coming up and don’t forget to sign up for the Victron trainings and events.
We have released Color Control GX v1.72 which contains bug fixes and support for new Victron products. Also it adds compatibility with the PylonTech lithium batteries, which we’ll explain more about in the next newsletter. Read more
VEConfigure
A new version of VEConfigure has been released. Most important changes:
1) Fix error message about Grid code error. Note that any installs that have had this error will need to reconfigured, using the now released version, to re-enable feed-in.
2) Fix index out of bounds error on 1xx, 2xx and 3xx firmware versions
180 and 350VA Phoenix Inverters
Just a reminder that we still have little stock left of the following ‘old’ units:
- Phoenix Inverter 12/180 Schuko outlet - 230V
- Phoenix Inverter 12/180 AU/NZ-230V
- Phoenix Inverter 12/350 AU/NZ-230V
- Phoenix Inverter 24/180 NEMA 5-15R socket – 120V/60Hz
- Phoenix Inverter 24/350 NEMA 5-15R socket – 120V/60Hz
- Phoenix Inverter 24/350 Schuko outlet - 230V
If you want to know more about the new Phoenix Inverter dimensions, you’ll find the datasheets and manuals with these dimensions on our website: www.victronenergy.com.
Updated documentation
We have updated the following manual with the newest information.
- BlueSolar charge controller MPPT 75/10 & 75/15
- Certificate Automotive ECE R10-4 – all IP22 chargers 12V
- Certificate Automotive ECE R10-4 – all IP22 chargers 24V
- Certificate Automotive ECE R10-4 – BMV 700, 702 & 702 black
- Certificate Automotive ECE R10-4 – Digital Multi Control 200/200A & 200/200A GX
On our website you can find all of our documentation.
METS 2016 Amsterdam
From November 15th – November 17th the METS 2016 is at the RAI Amsterdam in The Netherlands. The METS is the largest marine equipment trade show and has been bringing the marine industry together for decades. Come and see us at booth 01.541. More info on the METS website.
Upcoming exhibitions
Are you curious to know if there are any events in your area in the coming months? Just click here. Coming up in October/November:
- October 29th - November 6th: Hanseboot 2016 in Germany
- November 9th – November 13th: Müsiad Expo 2016 in Turkey
- November 15th – November 17th: METS 2016 in The Netherlands
Interested in trainings about our products?
In October/November we have the following trainings for you:
- October 31st – November 1st: Technical training for installers in Spain
- November 2nd – November 3rd: Self Consumption and Storage Systems Training – Lithium Ion Battery Systems in South Africa
- November 7th – November 8th: Formación técnica para instaladores in Spain
For more information about our trainings and courses go to events on the rights side of your screen.
