August 29th, 2016
Phoenix Inverter 48/500-230V with UK-socket in stock
In stock and available on E-Order, the Phoenix Inverter 48/500-230V VE.Direct UK.
Color Control GX v1.71
Since v1.70, the On/Off/Charger only switch, as well as the input current limiter setting, used old values after a reboot. This problem is now fixed, with the release of v1.71.
There are no other changes in v1.71.
Our apologies for any inconvenience caused.
Victron Toolkit app: Now supports even more products
The updated Victron Toolkit app version 2.3 has now been released. What’s new?
Updated documentation (also available on our website):
180 and 350VA Phoenix Inverters being replaced
As you know, several Phoenix Inverters will be replaced by new models with new dimensions. Below you’ll see a list of what little stock we have left of the ‘old’ units. On our website you can find the datasheets and manuals with the new dimensions.
Phoenix Inverter 12/180 Schuko outlet - 230V
Phoenix Inverter 12/180 AU/NZ-230V
Phoenix Inverter 12/350 AU/NZ-230V
Phoenix Inverter 24/180 NEMA 5-15R socket – 120V/60Hz
Phoenix Inverter 24/350 NEMA 5-15R socket – 120V/60Hz
Phoenix Inverter 24/350 Schuko outlet - 230V
