VictronConnect v1.9
Change log v1.9:
· Phoenix Inverter: Hide “Low battery shut down” setting when dynamic cutoff is enabled.
· BlueSolar MPPT: Make possible to select 36 and 48V battery voltage on BlueSolar MPPT 150/35 rev2
· BMV: Include BMV-70x firmware v3.08 update
And the previous one:
Change log v1.8:
· Include Phoenix Inverter firmware v1.03 update
· Fix Phoenix Inverter “Low battery shutdown voltage” setting is locked and showing “Dynamic”
Updated manuals and datasheets (also available on our website):
Phoenix Inverter 3k 5k 230V firmware xxxx1xx
Phoenix Inverter 3k 5k 230V firmware xxxx4xx
New models Phoenix Inverter
Several Phoenix Inverters will be replaced by new models with new dimensions. We still have little stock left of the ‘old’ units mentioned below. On the datasheets and manuals on our website you can find the new dimensions.
Phoenix Inverter 12/180 Schuko outlet - 230V
Phoenix Inverter 12/180 AU/NZ-230V
Phoenix Inverter 12/350 AU/NZ-230V
Phoenix Inverter 24/180 NEMA 5-15R socket – 120V/60Hz
Phoenix Inverter 24/350 NEMA 5-15R socket – 120V/60Hz
Phoenix Inverter 24/350 Schuko outlet - 230V
NICE TO KNOW
Victron sponsored Furia solar boat wins again
As you may recall, the CLAFIS Victron Energy solar boat team clinched the Dutch solar boat challenge, just before they dashed off abroad for the Monaco Solar Boat Challenge – which is billed as ‘A sport for the new generation, inspired by nature and powered by innovation.’ And inspirational it was!
Victron Energy people: Who is Ruurd ten Brink?
This blog is an insight into Ruurd ten Brink. It’s part of the ‘Victron Energy people: Who is who?’ series of blogs. So, who is Ruurd ten Brink?
