News overview
Solar Charger firmware v1.68 - Load output voltage thresholds bug fix
Firmware v1.68 for SmartSolar chargers fixes a bug where temperature compensation was incorrectly applied to the load output voltage thresholds.
Charging voltage is adjusted based on battery temperature: increases when it's cold and decreases when it's warm to protect the battery. However, these adjustments were also being applied to the load output voltage thresholds. This has now been fixed. Once the new firmware is installed, the load output disconnect value will only consider the actual battery state of charge, without being affected by temperature compensation, which will prevent early or delayed disconnections.
Full change log
For the full change log, see the Solar Charge Controller MPPT VE.Direct entry in the firmware library on Victron Professional.
How to install this update?
  • For systems connected to the VRM Portal, the recommended method is to use the VRM Remote firmware update feature. Detailed instructions can be found here. For more information on the VRM Portal, visit here.
  • For systems not connected to the VRM Portal, we recommend waiting for the next version of the VictronConnect App. This version will include the updated firmware and will automatically prompt you to update upon connection. If you prefer to update before this version becomes available, you can download the firmware file from the firmware library on Victron Professional and use the VictronConnect App self-supplied file update method.
