Phoenix Inverters 250, 375 and 500VA – Dynamic Cut-off
Recently released, about two weeks ago, is the new Phoenix Inverter VE.Direct firmware version v1.03, which besides a few internal changes, has a major new feature – the addition of Dynamic Cut-off. Some of you may know it from Hub-4. What it does is this: instead of using one fixed battery voltage as the low battery shutdown level, it also looks at the battery current. This makes sense, as we all know battery voltage drops when putting a load on it; caused by the internal resistance of a battery bank.
New and updated documentation (also available on our website):
Battery Protect 65A 100A 220A (D)
Orion-Tr DC-DC converters isolated 100W (D)
Orion-Tr DC-DC converters isolated 250W (D)
Certificate Automotive ECE R10-4 - 24V MultiPlus Compact & Inverter 2000VA
MultiPlus 3k 120V (firmware xxxx1xx) (M)
MultiPlus 3k 120V (firmware xxxx4xx) (M)
MultiPlus 3k 230V – 16A 50A (firmware xxxx1xx) (M)
MultiPlus 3k 230V – 16A 50A (firmware xxxx4xx) (M)
MultiPlus 5k 100A 230V (firmware xxxx1xx) (M)
MultiPlus 5k 100A 230V (firmware xxxx4xx) (M)
Phoenix Inverter 3k 120V (firmware xxx1xx) (M)
Phoenix Inverter 3k 120V (firmware xxx4xx) (M)
Quattro 3k 50-50A 120V (firmware xxxx1xx) (M)
Quattro 3k 50-50A 120V (firmware xxxx4xx) (M)
Quattro 3k 50-50A 230V (firmware xxxx1xx) (M)
Quattro 3k 50-50A 230V (firmware xxxx4xx) (M)
Quattro 5k 120V (firmware xxxx1xx) (M)
Quattro 5k 120V (firmware xxxx4xx) (M)
Quattro 5k 24v 48v 100-100A 230V (firmware xxxx1xx) (M)
Quattro 5k 24v 48v 100-100A 230V (firmware xxxx4xx) (M)
Quattro 5k 8k 10k 100-100A 230V (firmware xxxx1xx) (M)
Quattro 5k 8k 10k 100-100A 230V (firmware xxxx4xx) (M)
New models Phoenix Inverter
Just a reminder that we will be replacing several Phoenix Inverters by new models with new dimensions. We still have little stock left of the ‘old’ units mentioned below. On the datasheets and manuals on our website you can find the new dimensions.
Phoenix Inverter 12/180 Schuko outlet - 230V
Phoenix Inverter 12/180 AU/NZ-230V
Phoenix Inverter 12/350 NEMA 5-15R socket -120V/60Hz.
Phoenix Inverter 12/350 AU/NZ-230V
Phoenix Inverter 12/350 UK outlet - 230V
Phoenix Inverter 24/180 AU/NZ outlet - 230V
Phoenix Inverter 24/350 IEC outlet - 230V
Phoenix Inverter 24/350 Schuko outlet - 230V
Phoenix Inverter 24/350 AU/NZ outlet - 230V
Phoenix Inverter 24/350 UK outlet - 230V
