We are glad to introduce the Android GX Wifi Display: a simple way to turn any Android phone or tablet into a wireless display for monitoring and controlling GX devices.
The app can be installed on any Android device running version 8.0 or higher, and connects to the GX device over the same Wifi network. It is ideal for compact installations, where placing a display exactly where you need it is important and running cables can be tricky.
It is also a practical solution for larger setups, where you can install multiple Android GX Wifi Displays that work independently, making it easier to monitor and control the system from different locations such as on different floors of a building or compartments of a vessel.
Before setup, the Android device must be factory reset. Once the app is installed, the device becomes a dedicated GX display and won’t be usable for other tasks. It will stay locked in this mode until another factory reset. Also keep in mind that, while the connection is wireless, the Android device still needs a permanent charging source.
This new display solution is a practical option for systems that need more flexibility than our regular display solutions.
To get started, you can watch this video and read the Android GX Wifi Display
manual to access the QR code for downloading the app and to see the full setup instructions.
