December 11th, 2024
We have recently released firmware update v1.07 for the Orion XS. This update brings the following improvements:
- The Remote On/Off terminal behavior has been updated to pause the charge algorithm rather than restart it if it was switched off for less than 2 hours.
- Updates to hardware control and internal software improve overall system robustness and reliability.
Full change log
For the full change log, see the Orion XS entry in the firmware library on Victron Professional.
How to install this update?
- For systems connected to the VRM Portal, the recommended method is to use the VRM Remote firmware update feature. Detailed instructions can be found here. For more information on the VRM Portal, visit here.
For systems not connected to the VRM Portal, we recommend waiting for the next version of the VictronConnect App. This version will include the updated firmware and will automatically prompt you to update upon connection. If you prefer to update before this version becomes available, you can download the firmware file from the firmware library on Victron Professional and use the VictronConnect App self-supplied file update method.
