News overview
MPPT sizing calculator
Released today, the new and fresh design of the online MPPT sizing calculator.
If you haven't used the calculator before, it's the simplest tool to find the ideal match between your planned PV modules and the Victron Energy MPPT charge controller. You can find it here: MPPT sizing calculator
New Features:
  • Improved support for mobile devices/small screens through the new responsive design. So now easy use on all devices and this in 13 different languages.
  • Additional tooltips to assist, in selecting a suitable MPPT for your system setup.
  • We've added a wizard to guide you through the calculator, ensuring you configure your system correctly without missing any parameters.
Please note that the custom solar panels option has been removed. You can now select non-Victron panels directly using the solar panel search field. With over 164,000 solar modules in the integrated database, you will most likely find yours on the list.
Once you've completed your configuration, you can share or archive it using the export button located in the upper right corner of your screen.
