Today we released VE.Bus firmware version v506, together with new versions of VEConfigure, VE.Bus System configurator and VE.Bus Quick Configure.
Change log:
- Add the new Solar & wind priortiy feature. See https://ve3.nl/vebus-pr for further information.
- Bug removed from GridCode implementation.
When to update?
More so than most other Victron products, it is not recommended, nor needed, to keep the firmware in our inverter/chargers up to date. Stable operating inverter/charger systems are best left running.
Here is when to perform a firmware update:
- During commissioning / first install;
- When trouble shooting;
- To add a new feature that is required by the installation.
How to install
WARNING: updating the firmware of (VE.Bus) inverter/chargers is strongly adviced to be carried out by trained personel only. Doing the update will cause all settings to be reset to their default: requiring the product to be reconfigured.
For further information:
- End-users: please contact your installer.
- Professionals: see VictronConnect VE.Bus Configuration guide, Firmware update chapter.
A new version of VictronConnect, that includes this new firmware version is expected for release latest by mid august 2023. To install the update before then, download the required file from Victron Professional and use self-supplied firmware file update method as explained in chapter 9.2 in the VictronConnect manual.
