April 14th, 2023
For the EVCS & EVCS NS the new firmware 1.25 is now released.
Many new features were added:
● 'Battery powered' or 'Off-grid' auto mode algorithm. This is used by default
● Grid failing processing (it will enable charging if it was active before failing)
● Pairing between EVCS (NS) and GX device by VRM Portal ID
● GX device communication check button in general settings
● Bluetooth disabling from the Victron Connect application
Improvements:
● Improved GX device communication and error handling. Added additional messages to the web
interface in case of communication problems
● System performance improvements
Full changelog and manual firmware download in the firmware folder on VictronProfessional.
