News overview
MPPT sizing calculator - new features
Recently a couple of new interesting features have been added to the MPPT sizing calculator.
When calculating (bottom right in the picture) you can now:
  • Filter the results on MPPT features like 'Bluetooth', 'VE.Can', integrated 'inverter' or 'AC charger'.
  • Connection type 'terminals' or 'MC4'
  • Whether the customer would like to oversize the PV array more than 130% (what we recommend as the maximum economical efficient)
Using these filters the user compresses the list with results and this makes it more clear which MPPT to choose. It will now show the best technical solution and if 2 or more are comparable it will pick the least expensive one.
  • After restarting de MPPT sizing tool you will now see your last configuration and do not have to start all over as it is saved locally.
  • We also like to highlight the option that you can share and save your configuration by using the 'share your config' button (upper right in the picture). With that you can archive or share a calculation as the link will remain permanent. Besides this you can also download the configuration as a PDF.
Here is where you can find the online calculator: MPPT sizing calculator
