News overview
Victron Energy News - wk13 2016
NEWS
Now in stock and available: Blue Smart IP65 Charger
The Blue Smart IP65 Charger (with Bluetooth) is now in stock and available on E-Order. You can display the status of your charger and battery and even control the functions of your charger using the VictronConnect app. Download the VictronConnect app so you can setup, readout and configure your Blue Smart IP65 Charger via your smartphone.
Learn more: Blue Smart IP65 Charger
New: The VE.Can Resistive Tank Sender manual
The VE.Can Resistive Tank Sender adapter allows a standard resistive tank level sender to connect to the Color Control GX. For the adapter to work, the VE.Can network needs to be powered. When you use a Skylla-i or a MPPT with CAN bus in the system, the power to the CAN bus will be supplied by either one of them. When the CAN bus is not powered by a Skylla-I or a MPPT, you will need the new VE.Can Power Cable (– ASS030690000) to supply the power.
Learn more: VE.Can Resistive Tank Sender
VE.Can Power Cable
New and updated datasheets, manuals and certificates;
Buck-Boost DC-DC Converter 25A and 50A (manual)
Buck-Boost DC-DC Converter 25A and 50A (datasheet)
Phoenix Inverter VE.Direct 250VA – 375VA
Certificate AS/NZS 60335 – Blue Power IP67 Charger
Certificate AS/NZS 60335 addendum 1 - Blue Power IP67 Charger
Certificate AS/NZS 60335 addendum 2 - Blue Power IP67 Charger
Certificate IEC/EN 62109-1 – all MultiPlus 3kVA
Declaration of Conformity - EasySolar
All mentioned datasheets, manuals and certificates are available on our website.
