We are pleased to introduce the new Nucleo GX, a compact, high-performance GX device that brings Ekrano GX-level speed at a lower cost, thanks to a focused set of I/Os.
With its focused feature set, it is an ideal choice for ESS and off-grid installations built around the Multi RS.
Included I/O:
- 2 × VE.Can ports
- 2 × VE.Direct
- 3 × USB
- Ethernet
- WiFi
- Bluetooth
- Micro SD card
Not included:
- VE.Bus port
- Tank inputs
- Digital inputs
- Temperature inputs
- HDMI port for GX Touch display
- Relays
For local display and control without HDMI, the Android GX WiFi Display solution can be used. System access is also available through the VictronConnect app, a web browser and the VRM Portal.
Additional functionality such as VE.Bus connectivity, relays, or analogue inputs can be added via the following optional USB accessories:
Ideal for VE.Can-based installations such as RS systems, it provides full GX functionality with simple setup and remote access through VRM, LAN, or WiFi.
When having to add multiple accessories, do consider using a larger GX device instead. Both for total price as well as simplicity and reliability.
Features:
- Quad-core processor for fast, reliable performance
- Up to 25 connected devices via VE.Direct and USB, more via VE.Can
- Full remote access via Remote Console on VRM
- Real-time monitoring of battery, power consumption, and PV/generator/mains harvest
- Automated generator start/stop
- Alerts and diagnostics via VRM or local network
- Simple wall or DIN35 rail mounting
- Bluetooth setup via VictronConnect
For more details, including the product manual and datasheet, visit the product page on our website: Nucleo GX | Victron Energy
