News overview
New: Multi HS19 Solar 15k
We are pleased to introduce the Multi HS19 Solar 15k, our first inverter/charger designed for high-voltage, 650 - 1000V systems.
It combines three-phase power, battery charging, and solar tracking in a single 19-inch rack unit. High-voltage operation reduces current, cabling, and losses, while the 19-inch enclosure and low weight of just 26.5 kg make for a compact and easy installation. With a maximum inverter efficiency of 98%, system losses are kept to a minimum.
With four independent built-in MPPT trackers, each handling up to 8 kW, four separate solar arrays can be installed at different orientations, making the most of available space.
As part of the Victron ecosystem, the Multi HS19 Solar can be monitored and configured via Bluetooth using the VictronConnect app, or connected to a GX device for remote monitoring through the VRM Portal. Dedicated Battery CAN-bus and VE.Can ports ensure straightforward integration with compatible batteries.
At first, parallel operation is not available. Generator support will follow via a firmware update.
Ready for off-grid, backup, peak shaving, and grid-tied applications.
To learn more, visit our website: Multi HS19 Solar 15k | Victron Energy
